Well, spent all day today workin on it and made some progress. Doesn't look like much but I did a lot of cutting, welding, changing, etc. today.
Got the whole thing cleaned up, more primer, then lots of olive drab. 2x6's were coated with Thompson's water seal on all sides before putting them on. Layed it on pretty heavy and let it all soak in. Its the stuff with UV protection and such.
Couldn't decide what to do with the tail lights so just threw some mounts up high for now to keep me out of tickets. I have some ideas using different lights but these will work for now. Also threw another coat of water seal on the deck after on the trailer.
The deck has no screws/bolts holding it down. I boxed the front of the boards in with flat steel. After all the boards were in I did the same in the rear using several small stitch welds. If I need to replace a board I just have to grind a few welds to get the boards out. I also added a channel upright on the back for a removable gate. Basically a piece of plywood that will slide into place. I am going to finish wiring the lights in the morning then take it to the hardware store for some plywood/paint and finish the sides. Going to use a 2x4 along the bottom and then plywood up.
