It is currently Thu Feb 09, 2012 8:51 am
Post new topic Reply to topic  [ 10 posts ]
 Chase rack idea
Post Chase rack idea
This is the rack I was telling Jose about. Holds 2 35x12.50s and 4 33x10.50s it has a hose reel set up and the air bottles strap to the center bed brace, with room to turn on the regulators from outside of bed or through the slider.room for generator and welder under tires.Also has a high lift mounted on rear bar.Built from 2x2 box with triple walled bar going through wheel centers,locked with a reciver hitch lock.High lift also has reciver hitch lock. sweet setup provin theft proof in baja.
[attachment=0]RAY BROWNS CHASE RACK 003.JPG[/attachment
Life is not a journey to the grave with the intention of arriving safely in a pretty and well presurved body,but rather to skid into heaven broadside,thoroughly used up,totally worn out and loudly proclaiming...WOW WHAT A RIDE! NOW WHATS NEXT!!!!!
Last edited by prerunnerinidaho on Mon Feb 16, 2009 2:08 pm, edited 2 times in total.
Mon Feb 16, 2009 1:42 pm
Post Re: Chase rack idea
sorry for all the same pics im gettin off this dam lap top and fix and load more pics
Mon Feb 16, 2009 1:47 pm
I like that setup.
Mon Feb 16, 2009 2:05 pm
more pics
Mon Feb 16, 2009 2:10 pm
still more pics
Mon Feb 16, 2009 2:12 pm
I like it too, though I would probably haveall the legs to the the bed floor. I can't imagine the bed rails were designed to support that much weight.
~Don Healy
you could put one in the center at the rear. he rallys his truck and no damage so far in four years loaded in baja.this should hold 6 of el chivos hoofs
Mon Feb 16, 2009 2:16 pm
Yeah, a rear support in the center, then the sides would just be for balance ....
That is a great idea. You could also make some drop in holes for our fuel cans too.
~Don Healy
Mon Feb 16, 2009 2:27 pm
you can see box sleeved in to beef it up the center as well.angled off the bed rails for lateral stability. lots of room left in his short bed f-150
Mon Feb 16, 2009 2:45 pm
Grand Pumba
Ideas are starting to roll around . . . or maybe those are cobb webs?
PascoAutoWrecking.com
Fri Feb 20, 2009 10:00 am
Profile
