Tow rigs from Parker . . .
If your rig was lucky enuff to be at Parker you might want to check the undercarriage!
I've been thinking my brakes were going out/needing replacement since we got back. Well today I pulled the fronts off to see if I needed rotors turned or anything else, and it's all new under there!
Exept for dried mud/clay/rocks packed EVERY WHERE!!! It was binding the floating calipers, pluged the cooling fins in the rotor, imbeded in the brake pads themselves!
This stuff is awfull, go pull a wheel and check your junk!!!!
